using oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2013, 10:43 AM
using oil
I rebuilt my boat motor,v6 vortex using moly rings thinking they would hold up to the constant 3000-4500 rpms the motor would be at most of the time.The problem im having is its using a qt of oil every 5 gals of gas.Ive run it out on the water for about 2 hrs at different times.Motor runs great.HELP,I don't want to rebuild the motor.Any help would be great.
Old 10-01-2013, 10:48 AM
vinniekq2's Avatar
have you traced where the oil is escaping?
Old 10-01-2013, 11:10 AM
oilburning
I have no leaks and no smoking ,don't know why it's using oil so fast.
Old 10-01-2013, 11:23 AM
vinniekq2's Avatar
it either leaks externally or internally.
external,common areas=VCs or back of intake.
internal=rings or guides
look at plugs and wipe down engine with dry white cloth. clean oil on a new engine is almost invisible.
moly rings are sometimes hard to seat if the wrong finish is used on final hone.
The Following User Says Thank You to vinniekq2 For This Useful Post:
sportcraftbob (10-03-2013)
Old 10-03-2013, 10:56 AM
oil burner
When engine was checked out I didn't know I was putting moly rings in it.The shop did hone cylinders,but they didn't know I was putting the moly rings in it.The motor is in a boat,bilg is spotless,no oil leaks.165 degree thermostat in it,it works great with gauge.Should I get more oil and run it more.Do you know I should go about breaking it in.Thanks for your help.
Old 10-03-2013, 11:05 AM
techinspector1's Avatar
Wiki Edits: 326
Don't know about your oil disappearance, but not a fan of cold thermostats. Motors need to run at higher temps to burn off acids and other contaminants that are a by-product of combustion. Change it out to a 205 degree thermostat.
I'm not sure how the moly rings would work on a surface that was probably honed for cast rings, but I'm thinkin' not very well.
Old 10-03-2013, 07:11 PM
Im a mercruiser tech. as far as would go do a leak down might be going out exhaust valves, any chance oil slick in the water at all tie her up good and put it in gear 2000RPM. Id leave the thermostat you have in or even take it out these engine need as much water as they can for them big water manifolds, 205 is hard on the soft rubber like the fresh water impellors.
Old 10-03-2013, 08:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Moly rings break in very quickly when the finish is correct- which is finer than standard cast iron rings. Moly inlay rings and to a lesser extent plasma moly rings will wear quicker on a rougher-than-needed bore finish. If the bore is too rough the rings will wear rapidly, causing the end gaps to open and a loss of tension and they may not seat properly. There has to be a proper crosshatch hone pattern for the rings to break in correctly as well.
Check the plugs. If the rings or guides are passing oil they'll show it. A recent thread on this is here. If the second ring(s) were installed upside down, they'll cause oil loss into the chambers.
Are you using a PCV setup? Or breathers? What you do not want is a sealed or pressurized crankcase.
Oil Filter Adapter for 93 camaro to delete oil cooler? tylerwerrin Engine 4 09-23-2010 11:15 AM
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 04:40 AM
i have a 70 buick 455 fresh bottom end and new high out put oil pump still no oil pre tpisuper10 Engine 12 09-22-2008 09:26 PM
Vapor coming fro mthe breather and oil cap but not oil....????? 76 elco Engine 8 07-06-2007 04:35 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 01:56 AM
