using old intake manifold on new engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2012, 03:38 PM
Hey hot-rodder’s
I am going to use the intake manifold from 305 on a 350. I was suggested that I remove the aluminum section from the underside and clean out the built up crud. This has a couple of rivets holding it on. Is this worth the extra work?
Old 01-20-2012, 03:45 PM
Last journal entry: update
Yes, do it.
Old 01-20-2012, 03:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by low_and_slow
Hey hot-rodder’s
Sure. There will be all sorts of carbon built up under there. The tin/steel pan is held on usually by rivets that have a twist on them. If you use a thin sharp chisel to get them started they can be pried out fairly easily.
After cleaning, use carb spray cleaner to degrease the rivet holes and rivets and use loctite to reinstall them, or tap the holes for small machine screws. If the rivets are a little loose from being removed previously or from removing them this time you can use a small piece of copper wire in the hole to wedge the rivet tighter along w/the loctite when you tap it back down.
Old 01-20-2012, 08:48 PM
Intake Manifold/Thanks
Thanks so much cobalt327 and all you smart men and women who have come to my rescue. The going is slow but the end product will be an Elk that shows Chevy pride.
Engine build intake manifold choice Badazz93 Engine 4 02-28-2011 05:28 PM
383 intake manifold winko33 Engine 6 04-12-2009 04:05 PM
what intake manifold to use proge Engine 1 10-22-2008 02:31 AM
intake help?OFFenhauser low pro. ram intake manifold 74chevyflat Engine 0 05-17-2006 08:49 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 12:19 PM
