Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - using panel adhesive
Old 01-29-2007, 04:26 PM
kenseth17 kenseth17 is offline
I was replying to mels post. I see his said it would harden up whats in the tubes, not the tip. Anyway, if a two part I don't see how that could be a problem either, since both parts are in different cartridges and shouldn't harden if not mixed together, and when the adhesive it will seal things up if the tip is left on, or else you can put back the cap that normally comes on the tubes that you remove to put on your mixing tip.
