using pcv as a vacuum testing source - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 07:20 AM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
Might be a dumb question but since neither my Carb nor intake manifold have a test vacuum port, can I just unplug my pcv and test there? Or will that change vacuum readings?
Old 05-09-2012, 09:13 AM
F-BIRD'88's Avatar
Yada Yada Yada
The PCV is a slight vacuum leak to the intake manifold.
So ya it will effect the vac reading a bit.
You could add a T to the PCV hose to allow both the PCV and a vac gauge.
Where are the power brakes getting vacuum from?
Old 05-09-2012, 11:57 AM
Mach1460's Avatar
No power brakes, manual discs/drums. No power steering and no radio either
Converting a ported vacuum source to a manifold source Scrumgees Engine 2 08-17-2011 01:09 AM
Is there a "Best" Vacuum Source for PCV? acr Engine 5 05-28-2010 11:36 PM
Testing Vacuum Cannisters MI2600 General Rodding Tech 1 02-02-2006 09:50 PM
Testing a vacuum advance trenchdog73 Engine 1 04-20-2005 11:19 AM
Holley Avenger vacuum source for PCV AngliaBob Engine 2 04-17-2005 02:41 PM
