Using Permatex Right Stuff on timing cover oil pan seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2010, 01:47 PM
Hello guys I am getting ready to do my cam swap soon but have a few questions. I don't use the bottom rubber seal on my timing cover that seals over the oil pan but instead I have been using permatex ultra black gasket maker since it allows me to not have to drop my oil pan any and by angling it right I can get it pushed down on the pan then back up against the block and then torque it down.
But this time I am going to try to use the permatex black right stuff gasket maker and I have never used it before. Is this stuff really good and will I have enough time to make a good bead on the bottom of my cover and then get it placed on before it totally cures.
I am used to having to wait for it to cure and then being careful when installing my timing cover and then I take my finger and smear the excess gasket maker off to make a nice smooth looking seal. Will I be able to do the same with this stuff? Hope you guys who have this can give me your experience with it. I really hope to be able to use it since it will cure faster but I wont be driving it right after that anyways.
I will have to get all my other stuff put back together and also want to use this stuff for my intake front and back seals.
Thanks guys
Eric
Old 07-29-2010, 02:00 PM
delawarebill's Avatar
rtv..
i just replace my cam yesterday.. and if your only going to use rtv (any color) make sure it says its ok for oil contact. how about buying a 2 pc timiming cover??? thats what i use and love them.
Old 07-29-2010, 02:29 PM
Yeah a two piece cover would be nice but I only plan on doing this once so it won't do me any good cause if I ever have to replace something major the motor will come out of my truck. Anyways the right stuff and the ultra black are good against oil.
Eric
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
SBC 400 Rear main Vs Rear Oil Pan Seal afsog Engine 12 02-12-2010 04:56 PM
Thick front pan seal problem... or not?? biggeazy-e Engine 21 08-05-2008 11:17 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Engine Timing cover crank seal Buffed Engine 2 11-17-2002 07:54 PM
