Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using Poly Primer instead of Poly Putty in between Epoxy and Eurethane primer
  #18 (permalink)
Old 09-09-2011, 06:32 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
What are you using for sand paper? The biggest mistake most beginers do is try to finish with to fine of a grit. It's way easier to under cut the edge with fine paper.Try to use 80 grit untill you get the feel of it.
