Using a Primer Sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2004, 03:12 PM
Question Using a Primer Sealer
Hey all. In about 2 or so weeks i am ready to paint my trans am. Right now i am just coating everything in primer. What i need to know is can i just spray my paint right on top of the primer? Or do i need to use a primer sealer over top of the primer, and then paint? I've heard a bunch of different things, and sure could use the help.
Also, any ideas on where to get a flex agent for the paint and primer for urethane bumpers?
Taker er easy -Hansol
Slow Down?! What?!?
Old 03-28-2004, 03:27 PM
IT'S MY JOB...
Hansol,
Follow the recommended procedures from the paint manufacturer on their TDS, PDS, or P sheets. (whatever they call theirs). Also your local jobber will have the recommended flex additive and instructions. Bryan
Old 03-28-2004, 04:37 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
You can paint over the primer. But it is highly recommenced that you apply a good sealer over the primer, after it is sanded.
Primer is just used to fill scratches and leveling, like where you made a repair or are featheredgeing, the least amount you wind up with under the paint, the better the paint job will be.
Like blowing on flames says, you can get a flex additive at your paint supply store.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
