Using Repair Panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2006, 06:58 PM
Using Repair Panels
Hi-
I need to replace some rusted metal on both doors of my truck. The inner bottom and the outer door skin need to be replaced. I bought a repair panel for the inner bottom, and a skin for the lower half of the outer.
I've been reading some of the great tips and suggestions, especially on templates and welding. Before I jump off the cliff, I want to ask for some advice on how to cut, fit and weld these pieces in and still have something that fits and won't rust out (again!) in a few years.
Thanks!
Jimlas53
Old 04-05-2006, 07:17 PM
Wiki Edits: 31
if there full peices and not patch panals or skins, drill out the factory spot welds and pull the peice off.
Old 04-05-2006, 08:23 PM
milo's Avatar
point on positive
Some times you can use the same templet to cut the panel that guides the patch... ...
heres some pics to click on to help motovate
http://www.a2zautoforums.com/showthread.php?t=700
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Repair panels aceandslick Body - Exterior 3 03-18-2005 08:26 PM
Rust Repair Panels for a 1947 Oldsmobile 60Belair Body - Exterior 5 07-14-2004 05:06 PM
Ford A & B Piller repair panels 40tudor Body - Exterior 0 07-17-2002 09:53 AM
rust repair panels lennyb Body - Exterior 1 05-28-2002 05:57 PM
