Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - using an S10 chassis under 63 nova
Old 03-25-2006, 01:27 AM
86078's Avatar
86078 86078 is offline
you lift,you lose!
Originally Posted by jvsapp
i'd still keep the s10 frame. still can use it under other things. also you may be able to use the rotors and calipers on your nova, just gotta get the brackets.. and the later model spindles... i think a s10 frame would go nicely under my morris though... but at 85" wheel base it is a little short...
Is that a shortbed,standard cab??? How about a extracab or longbed???
