using an S10 chassis under 63 nova - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-25-2006, 11:14 AM
Chopt 48's Avatar
First series S-10 wheel bases are listed as 108.3 and 117.9 .
The wheel base on the early Nova is 110. A redrilled spring pad would probably take care of that similar to what you do when putting an open drive rear under an early chev.
scrolling down on this page gives most of the specs on the S-10's
http://www.edmunds.com/insideline/do...ticleId=104456
  #17 (permalink)
Old 03-25-2006, 11:47 AM
86078's Avatar
you lift,you lose!
Originally Posted by jvsapp
my morris... is 85" not sure what the s10 wheel bases are... but i think the blazer was 100" or something like that... i would have to shorten some 15" to fit it in my morris traveler....
by the way i found this site that can give you ideas on your s10 frame....
http://www.rodster.com/rodsterfaq.htm
didn't we hear somewhere that S-10 frames are slide suspension????
  #18 (permalink)
Old 03-26-2006, 02:59 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
i heard that there is a weld that can be cut and the frame slid in, but i think it would be still too long...
  #19 (permalink)
Old 03-26-2006, 11:32 AM
Chopt 48's Avatar
Kit Car Magazine is doing a 40/41 Willys Pickup on an S-10 chassis http://kitcarmag.com/projectbuild/0603kc_hauler/ There are some good photos here that might be usefull.
On the frame slide thing. If you look closely at the frame it appears that the front subframe connects to the side rails in the area even with the front of the transmission pan in the lead photo in the story. it might be possible to cut those welds and slip the frame a few inches to correct wheel base length.
I did much the same thing at the back of a 75 Monte Carlo frame that I put under a 51 Merc.
  #20 (permalink)
Old 03-28-2006, 08:36 AM
tyman00's Avatar
Don: I know that you aren't using the stock 51 Box, but I was still wondering what S-10 chasis you used? Extended cab/short box, reg cab/long box? I enjoy seeing photos of your project.
  #21 (permalink)
Old 03-28-2006, 09:56 AM
jvsapp's Avatar
yeah i think it looks like it is right after the trans mount. hmm.. now i really have to rethink what i'm going to use on my morris... maybe a bac halfed s10 would be cheaper and better than getting a morrison or fatman chassis made. well better for street use anyway... but i didn't know that the monte did the same thing...
  #22 (permalink)
Old 03-28-2006, 10:57 AM
86078's Avatar
you lift,you lose!
I see it too...looks like it could work...i think somebody posted 108 & 117... ...i know where theres two right now...a std cab longbed & a xtra cab shortbed...but if we're only gonna back half it what the hell...this is were that WyoTech education woulda come in handy...i didn't know montes had it too...i've heard that people used the front clips though...hey maybe a subscription to KitCar???
  #23 (permalink)
Old 03-28-2006, 02:41 PM
tyman00's Avatar
http://ad-engineering.com/TechnicalInfo.html
On the right hand side of the page there is a little more information on the S10. Should give you a little better idea on wheelbase.
  #24 (permalink)
Old 09-28-2012, 10:16 PM
well interesting ! I wanted to do a morris on a s 10 too !,been reading as much as i can on it , have you found a s10 that one year is better to use than another ?, and the track also, would it look right under the morris ?, saw the fatman setup, just too expensive for me, but i do have a chev. 402 and turbo 400 with no place to go so i liked the s10 idea under the morris, any things i should know about ? other than its alot of work. thanks for any help, love this site, just found it and i could read all night !
  #25 (permalink)
Old 09-29-2012, 08:28 AM
RWENUTS's Avatar
You know nybronc if you look in the top left hand corner of the post you'll see a date and a time.
This thread is almost 7 years old.
Do you think you might get an answer?
  #26 (permalink)
Old 09-29-2012, 09:47 AM
date
didn't notice the date, people usually stay on web sites like this for years , once into cars, projects ect., you usually always have something going , well if any others have done this swap i'd like to hear from you.
  #27 (permalink)
Old 09-29-2012, 10:31 AM
RWENUTS's Avatar
Start a new thread.
  #28 (permalink)
Old 09-30-2012, 05:17 PM
Chopt 48's Avatar
And reason enough that Threads should automatically lock after six months of inactivity on all forums and only be reopened by the original poster.
I can't see why you would want to put that bulky suspension under the front of the Morris though when there are better options even if you might have to save your money for a while to do it. The S-10 Frame is not the universal fix all that some people tend to think it is.
Ask yourself "Do I really want a big bulky GM suspension under the front end of my rather small Morris?"
You also have to remember that the steering box and steering linkage is/are out in front of the crossmember and cause their own issues especially on a small car.
Like you the original poster has a very low number of posts so I'd imagine that he is still lamenting cutting the floor out of his heirloom Nova and attempting to cobble the S-10 frame under it long after the whole thing went to the junk yard. If he had succeeded we would be looking at a build thread in the archives.
The Following User Says Thank You to Chopt 48 For This Useful Post:
johnnyg (09-30-2012)
  #29 (permalink)
Old 09-30-2012, 10:34 PM
I can not imagine what a cobbled up mess that Nova with an S10 frame would be like! Those cars are sooooo sweet, what a shame it would be. And how easy it would be to make a nice frame from scratch under it that looks like it belongs there.
  #30 (permalink)
Old 10-01-2012, 09:18 AM
Chopt 48's Avatar
All too many people would rather cobble something together trying to save a few bucks (I've been guilty) rather than saving up and doing it right.
Often the same guy who tells you he can't afford a 1500 custom built subframe will easily spring for a set of billet wheels and matching tires that cost twice that and never flinch at that price.
S10 Chassis spikedog General Rodding Tech 3 11-05-2005 07:36 AM
63 Nova Front & Rear Seats Mustangsaly Interior 3 10-13-2005 09:44 AM
63 nova discs jtdchevy Suspension - Brakes - Steering 6 05-11-2004 11:35 AM
Audio parts 63 nova wagon.... 63novawagon General Rodding Tech 7 09-05-2003 02:04 AM
Sheet metal surgery 63 Nova convertible Mike Torn Body - Exterior 1 01-08-2003 12:10 PM
