![]() This is not a job for the timid.....The Nova body will flex all over the place with the structural support the unibody floor supports give....IF you are determined to do this... ....then I suggest making a lot of inner braces going from one side to the other to keep the body panels in alignment.IF you are doing a post car......it will stand it a little better than a hardtop car..... There are a LOT of things to consider..... 1) wheelbase 2) track width 3) body support 4) ride height Not counting the usual things......like a good place to work, your tool access and your skill level.......
unless your going prostreet the s10 is going to be way narrow. there are much better ways to go. a front sub is the best way to go and even a back half is easier. i just put a 46 sedan on an s10 and theres way more to it than just setting it down on the frame. the rear kickup is going to be in your rear floor board. might want to rethink this one.
Thanks
I understand there could be tons of problems that I might run into, but if it works, the overall result will be completely rewarding! Disc brakes, solid frame, more room upfront for a larger motor, wider tires, cheaper parts
on another note, someone on hotrodder gave me this idea a long time ago and it took a lot of debating to decide. If it works, great... if it doesn't then you learn from mistakes! Right?! Thanks for the insite Tory
NO/NO-The S-10 front track is way too narrow. It will look awfull & you will have a car that has less value.
The s-10 suspension is no better than what you now have. If you want it to handle better go w/stiffer lowering coils in the front along w/a disc brake set-up. You can also improve the rear leafs. |
[QUOTE=Don Meyer]NO/NO-The S-10 front track is way too narrow. It will look awfull & you will have a car that has less value.QUOTE]
I'm more towards sentimental value not dollar value. Of course there are more expensive, simpler, sensable ways to convert to disc brakes and better suspension, I'm stubborn. Everyone has a mustang or heidts front clip... An S10 has the capability of swapping a small block into the normal pickup and without the inner fender wells on the nova, modifying the firewall, other problems seem minor (unless I'm forgetting something). Don, have you tried anything with an S10 frame? |
I've gotta agree with Shine & Don...there are tried & true front & rear clip kits out there...i understand that you've got the frame already,But the little things that add up might run your wallet dry in the long run...coulda bought a kit & been done with it,kinda deal...why reinvent the wheel when there's things that work out there already...
gooluck...keep us posted... |
Unless the floorpan in the Nova is already bad I'd have to vote with the guys who suggest going with a subframe conversion.
The S-10 conversion would work but you are still going to have to build a complete floorboard system and body support system. As far as tread width I don't think that they are that far off. The early Novas are pretty narrow themselves. Here is a site that you can make good use of http://www.novaresource.org/dimensions.htm#1963 If my old eyes are reading that white print right stock tread width is 56.3 Inches. |
my morris... is 85" not sure what the s10 wheel bases are... but i think the blazer was 100" or something like that... i would have to shorten some 15" to fit it in my morris traveler....
by the way i found this site that can give you ideas on your s10 frame.... http://www.rodster.com/rodsterfaq.htm Last edited by jvsapp; 03-25-2006 at 02:09 AM. |
| S10 Chassis | spikedog | General Rodding Tech | 3 | 11-05-2005 07:36 AM |
| 63 Nova Front & Rear Seats | Mustangsaly | Interior | 3 | 10-13-2005 09:44 AM |
| 63 nova discs | jtdchevy | Suspension - Brakes - Steering | 6 | 05-11-2004 11:35 AM |
| Audio parts 63 nova wagon.... | 63novawagon | General Rodding Tech | 7 | 09-05-2003 02:04 AM |
| Sheet metal surgery 63 Nova convertible | Mike Torn | Body - Exterior | 1 | 01-08-2003 12:10 PM |
