Using a saginaw 4 speed behind a 1993 Lti Corvette engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2005, 08:09 PM
I have a motor and trans from a 1993 Corvette Donor car. The trans is a 700r4 and the engine is a Lt1350. I bought a 4 speed saginaw transmission from a swap meet also bought the pedals and pedal accs. I still need the shifter assembly. I bought a 403 bellhousing and The right fork(long) for the saginaw. I have the 1 ring model 2.54 1.88 1.44 1.00 . My question is what flywheel will work on that motor trans set up. Also cant seem to identify my trans it has the 3 places for the linkage in the side cover but no holes in the tailshaft for mounting a shifter. Someone said takes a special bracket. I would be happy to email someone some pictures if they could help me identify. Thank you and I am in dire need of help here Thank You
Old 10-24-2005, 08:23 PM
poncho62's Avatar
Wiki Edits: 5
My 68 Beaumont (Chevelle) had one of those. The shifter was mounted on the tranny crossmember. Would get the linkages all bent out of shape when power shifting.
Old 10-25-2005, 01:11 AM
That bellhousing requires a 153-tooth flywheel (12-3/4" diameter). You'll need one with the smaller crankshaft bolt pattern for the one-piece-seal crank in the '93 engine. GM sells them under PN 14088650 for standard weight (~30lbs.) and PN 14088646 (~16lbs.). I wouldn't use the lighter one unless you have steep rear end gears. You'll have enough trouble starting from a dead stop with the heavy one if you have less than 3.42 gears. Clutch diameter will be limited to 10.4" or less.
You might be able to find a tailshaft housing that will accept a shifter mount from a trans rebuild shop, either local or on-line. Or, you might check with Hurst/Mr.Gasket & see if they make one that uses a bracket that bolts to the main transmission case.
If you find a factory shifter that mounts on the crossmember, they do tend to bind up on a hard shift. My '72 Nova has one, but I had a welding shop remove the S-curve in the handle, and it shifts much better now.
Old 10-25-2005, 03:39 AM
I had a Hurst comp plus on a muncie about 20 years ago, it had a plate that mounted to the top of the gearbox mount and had a u - bolt around the tailhousing. I suspect it may have been a Hurst/indy mount cobbled up, but it worked well with no binding. Most local sags had no bolt holes so when the shifters were upgraded this style of mount was used. Check out 3 speed sags and use their aftermarket mounts.
Old 10-26-2005, 08:07 AM
MI2600's Avatar
Member# 3287
I recently sold a 4-speed Saginaw that had two U-bolts around the tailshaft that held a plate on the left side for the shifter, similar to what Ian said. They almost looked like a couple muffler clamp bolts.
Old 10-26-2005, 01:25 PM
Should I switch Bellhousing to the bigger one
I have a 403 bellhousing for my 4-speed Saginaw. I understand that I will only be able to use a 10 and a half clutch with this bellhousing. I am running a 1993 350 LT1 from a Corvette 300hp stock. Should I upgrade to the bigger bellhousing or should the one I have work? I havent purchased clutch yet. Any help one this matter would be apreciated
Old 10-26-2005, 09:11 PM
I didn't mean to infer that a 10.4" clutch was too small. It's plenty big enough, and you'll have better ground clearance with the smaller flywheel & housing. The starter will also be closer to the block, decreasing the chance of header interference.
Old 10-28-2005, 06:47 AM
Some ls6's (real ones - 454/450hp) had a 10.5 in clutch, just a big ol pressure plate.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Automatic Tranny: whats best for a hi horse corvette or crate engine? blakblur Transmission - Rearend 1 10-16-2003 05:33 PM
Corvette Engine ?? akersa Engine 4 10-04-2003 04:30 PM
