Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using tach/dwell meter
Old 03-24-2010, 05:36 PM
lanierledford lanierledford is offline
Marcel
Last journal entry: Choo-choo town
using tach/well meter
there should be to leads, 1 red which would go on the - post on the coil and the other to ground. there should be a selector for 6 or 8 cyl. .use 8 for 4 cyls. and set it double. if there are 4 leads, then it would hook to the battery, but never seen on that had a battery hook up.
