Using tach/dwell meter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 04:51 PM
I have an older Hanson/Hawk Tach/dwell meter for 6 or 8 cylinder engines and don't really know how to hook it up. It just has two leads, red and black, with alligator clips. I'm trying to set up my 1981 Camaro with HEI ignition.
Old 03-24-2010, 05:08 PM
poncho62's Avatar
Wiki Edits: 5
With HEI, there is not use for a dwell meter........its non adjustable, as points are.
Old 03-24-2010, 05:33 PM
I need to set the idle though the car doesn't have a tach...
Old 03-24-2010, 05:36 PM
Marcel
Last journal entry: Choo-choo town
using tach/well meter
there should be to leads, 1 red which would go on the - post on the coil and the other to ground. there should be a selector for 6 or 8 cyl. .use 8 for 4 cyls. and set it double. if there are 4 leads, then it would hook to the battery, but never seen on that had a battery hook up.
Old 03-24-2010, 05:41 PM
Sinister's Avatar
For HEI hook up the red lead to the tach connector on the cap of the HEI. Black lead to ground.
causes for high volt meter reading +16 ! wheel-7 Electrical 3 05-11-2008 04:13 PM
AMC tach, voltage meter and neutral saftey switch. Javelin360 Electrical 9 08-18-2007 03:50 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
single wire Alt. & Amp. meter streetrodderdoug Electrical 2 12-12-2005 04:10 PM
how to ajust carburetor with air/fuel ratio meter Ratoflic Engine 3 07-25-2005 10:12 AM
