Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using TBI fuel pump with return reg on carb
Old 02-22-2012, 05:53 PM
brad33478's Avatar
brad33478 brad33478 is offline
well i unhooked the return line right before the evap canisters and ran a hose into a pan.
when i turn the key on the pump kicks on like normal and spits fuel through the return line but then shuts off after a second.
is this normal? or should the pump be consistently running and returning fuel all the time?
