Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using TBI fuel pump with return reg on carb
Old 02-22-2012, 06:27 PM
FmrStrtracer FmrStrtracer is offline
If you are running the pump off the original EFI circuit, the computer shuts the pump off after a short run unless it see's a tach signal that tells it the motor is running.
