Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Using TBI fuel pump with return reg on carb
Old 02-23-2012, 05:21 AM
brad33478's Avatar
brad33478 brad33478 is offline
I'm trying to keep the 4l60e currently with a carb tps kit from Holley and tach signal, the VSS is in the trans. I was told that's all the TCU should need for inputs. I also swapped over oil and temp sensors.
Thanks for the info on the evap that sounds like a good set up for me
