Using touch-up paint tubes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2007, 09:48 PM
jray's Avatar
Ok guys, I have been around painting etc enough to know I don't know what I am really doing. I just bought a tube of touch-up paint from the Dodge dealer for a couple of very small scratches and chips on my new truck.
Tube has lacquer paint so how do I get the best looking job out of this??
Lay on layer by layer until even or above existing paint then sand and buff ??
I know we have some experts on here....
Thanks, jayray
Old 08-24-2007, 11:14 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Since the experts haven't replied, I will instead
I usually tape as close as possible to the scratch so I can
brush on one good wet coat as thin as possible.
(Metallics are bad about the metallic floating to the top
if you put it on to heavy-like a drop, then it won't color match.)
I do that several times, untill it is at least as high as the surrounding paint.
Then when you pull the tape you can sand lightly and buff.
You got to be careful though, and check with a test on something else
first, some colors will change a little when you sand and buff.
Generally I don't sand and buff. It never looks as good as I want but
is better than nothing.
Old 09-01-2007, 11:00 AM
jray's Avatar
Thanks, Jcclark. Sorry for not replying sooner but went in hospital with pneumonia right after I posted and just now got back to reading the board.
That's pretty much what I had in mind but it has been many years since I messed with touch-up paint and would like to make sure I get this the best-looking possible.
jayray
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 05:34 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
