Using used rear end gears? good or bad - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2003, 08:09 PM
Muscle car fan
I got some used 3.50 gears for my 9" in my street car
I was wondering if there was any problems with using used gears?? they still look in good shape and everything
put em in and hope for the best?
'74 Gran Torino Project
351W, c6 trans, 9"
Old 11-13-2003, 08:38 PM
BOBCRMAN@aol.com's Avatar
The biggest problem is getting a good correct pattern on them after install in the next housing. If they were correct the first time and have little wear then they will usually set up again, but if they have an unusual wear pattern or are worn, they will be a pain to set up and usually noisy.
Old 11-13-2003, 08:46 PM
Muscle car fan
the wear pattern on them looked ok, they were a factory installed part
no big problems other than being noisy though? my car is going to make a fair bit of noise so i'm not too conserned about that
351W, c6 trans, 9"
Old 11-13-2003, 09:30 PM
I prefer a good used factory FOMOCO 9" gear set to a new aftermarket set.
I can get them to run quieter.
Most aftermarket ring and pinions have a good bit of runout and the influe is not as good as FOMOCO stuff.
Even Ford Motorsport IS NOT factory Ford anymore......they are sourced from the aftermarket.
Old 11-13-2003, 09:37 PM
Muscle car fan
the gears are original ford
351W, c6 trans, 9"
Old 11-17-2003, 07:46 PM
Muscle car fan
anyone else before I commit to these?
351W, c6 trans, 9"
