Using a vacuum gauge to determine carb size - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2012, 10:25 PM
DENCOUCH's Avatar
Can a vacuum gauge be used during a WOT run to determine if a larger carb is needed?
I was rolling this idea around & it seems to me that if manifold vacuum showed a steady build in the upper rpm range, the motor (providing it was built to rev) could use a larger carb.
Am I on track with this?
Old 01-24-2012, 10:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Basically, yes. This assumes no restriction from the filter element/air filter assembly and no excessive exhaust backpressure is skewing the results, no vacuum leaks, etc.
I should probably mention that air turbulence across the top of the carb can cause problems that may look like the carb is pulling vacuum at high speeds. This could be due to reasons besides the carb size. This is sometimes found when running a scoop w/o a filter housing, that sort of thing.
carb tune with vacuum gauge 350pano Engine 2 05-21-2009 01:49 AM
vacuum leaks and vacuum gauge GMR Engine 7 09-12-2008 07:14 AM
vacuum gauge to determine flow??.... sc2dave Engine 12 12-22-2004 11:00 PM
how to determine gear size mr.chevelle Transmission - Rearend 7 08-04-2003 04:23 PM
How to determine Engine Size ? SupergasserStudie Engine 5 11-24-2002 05:01 PM
