usual 9 inch going into a nova questions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-07-2010, 02:06 AM
well i ahve the next two days off. so i can going to be getting alot done. i need to knwo how much you wanted for those axles big gear head? i am going tomm morning to hopefully find a posi in the u pull junkyard. hopefully i find something good. i was thinking of getting a 4.56 gear for the reason of it being a real redlight beast. but could i still drive like 70 and still punch it down the highway?dont need to go faster than 100
  #17 (permalink)
Old 02-07-2010, 09:19 AM
big gear head's Avatar
High Performance Rear Ends
A 4.56 isn't going to be any fun on the highway. Your cruising speed is probably going to be around 45 MPH. I'll have to ask about the price onthe axles. They cost $495 new with the c clip eliminators. He will probably sell them for around $400. You will need a 33 spline spool to go with them.
  #18 (permalink)
Old 02-07-2010, 09:37 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
please take the discussion of parts sale to the PM system
  #19 (permalink)
Old 02-07-2010, 10:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by nova327
....alummy rad 16 electric fans.
Curious where are all those fans are mounted?
Semper Fi
  #20 (permalink)
Old 02-08-2010, 01:01 PM
well i actuall y havent installed yet but i know i have the room oin the face of the radiator. i am going to be looking into a posi over the spool. i only want to mess with the rearend once. can i do 65 with
410s?
  #21 (permalink)
Old 02-08-2010, 01:32 PM
Yea, you can do 65 with 4.10s, but you probably won't like it.
  #22 (permalink)
Old 02-08-2010, 03:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
http://www.corral.net/tech/gearcalc.html
Semper Fi
  #23 (permalink)
Old 02-08-2010, 06:15 PM
If you are going to use a posi then you will have to use 30 spline axles instead of 33.
I have 4.11 gears in my car and I can run 80+ without a problem, but I have 32 inch tall tires. That makes a big difference. My 427 doesn't like to run below 2500 RPMs, so the 4.11 works well for me. A 26 or 27 inch tall tire is going to increase the RPMs a bunch with the 4.10 gears. If you can run a 28 inch tall tire then the 4.10 might be fine for you.
  #24 (permalink)
Old 02-08-2010, 10:11 PM
they make posi for 28 spilne dont they? they are all on ebay and what not. I wish they had a a 390 gear but all i have of a choice is 373 and 410, guess i will go with the 410 and just get bigger tires for my dialeys
  #25 (permalink)
Old 02-09-2010, 06:18 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Tall street tires and shorter slicks is a better plan anyway,
  #26 (permalink)
Old 02-09-2010, 07:46 AM
Be carefull with those ebay differentials. There are a lot of people on there selling the Governor Lock as an Eaton Posi. The Gov Lock is made by Eaton, but it is not an Eaton Posi. If youa re looking for a stock 8.5 differential then you will be looking for a Traction Lock, which has the S spring in the center. Be sure that you get a 3 series and not a 2 series. The 3 series has the casting number 410408. Don't get the 410409.
406 sbc, build questions manchildau65 Engine 53 04-03-2010 07:59 PM
I'm the new guy with a lotta questions. Can you answer all of 'em? LittlePwny Engine 17 04-10-2009 03:08 AM
Unibody Rollbar Question Thump_rrr General Rodding Tech 37 03-10-2009 11:55 AM
9 inch ford G body rear axle questions, advantages STD spring, coil over eatonde Transmission - Rearend 9 01-21-2009 12:11 PM
9 inch question 19nova72 Transmission - Rearend 7 03-12-2005 04:15 PM
