usual 9 inch going into a nova questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2010, 11:15 PM
i have a 75 nova and i am hopefuuly installing a 9 inch rearend out of a late 50's truck. it has disc brakes and 370 gears. i am going to install a mini spool also. the rearend has huge drums. i paid 175 for the rearend. well i am worried that with the install my stock driveshaft wont work due to size and getting a u joint to fit. also how hard of an install is that 9 inch going to give me?
Old 02-04-2010, 06:06 AM
big gear head's Avatar
High Performance Rear Ends
If the width is right and the pinion offset is close then all you have to do is cut off the old brackets and weld on a set of Nova spring perches. The drive shaft might be too short, especially with the truck yoke. You might need to get a longer drive shaft. You know that the bolt pattern for the wheels is different.
Old 02-04-2010, 06:21 AM
327NUT's Avatar
Ok you say the rear end has disc brakes then you say it has huge drums, which is it?? No your stock drive shaft won't fit, you may have to have a complete custom built shaft made. If your stock one is long enough and is the proper diameter a good drive line shop may be able to fit and weld a 1310 or if need be a 1350 universal that will match up to the yoke on the 9" rear.
Your last question is totally up to your mechical knowledge and abilty.
Old 02-04-2010, 11:29 AM
well i know i can do it i have alot more on my plste and finished it. it does have drums on it i apologize for the confusion. how much is drivesahft to be made?
Old 02-04-2010, 01:13 PM
Just wondering, is there something wrong with the 8.5 10 bolt that came in the car? What are you going to do with the 10 bolt?
You can get reproduction Nova spring perches from Moser Engineering, Tom's Differntials and several other places. They cost about $60 a set.
Old 02-04-2010, 02:37 PM
nothings wrong with the 10 bolt in it. i just dont think it will be strong enough for what i am trying to do. i have a 327 10.1 compression forged, cam is about 525 lift and 280 duration, the heads are cast but port and polished 1.94 valves bronze guides. i have a vic jr and a 750 dp holley. i have hedman big comp headers. 1.6 roller rockers. 7 qt moroso pan, mini torque gear reduction starter. msd hei dist 125 shot of nitrous. alummy rad 16 electric fans. a serpetine belt set up. it has a non posi 372 gear. i want a 411 gear wth a spool. will the ten bolt work and whats my guess hp and torque. cam is a solid flat tappet
Old 02-04-2010, 04:22 PM
The 8.5 10 bolt is a strong rear end when built right. I have built many of them with a new 30 spline Eaton Posi and 30 spline Moser c clip axles. This upgrade makes them comparable to the 12 bolt. If you were not so far away I would buy it from you.
Old 02-04-2010, 05:18 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
There are a bunch of cars running 10s and high 9s on beefed up 8.5 rears, I don't think you're there yet,
Old 02-04-2010, 07:32 PM
ericnova72's Avatar
More for Less Racer
Last time I really looked there were guys in the mid 8's in the 1/4 on a beefed up 8.5" 10-bolt. Everything in them is close to the same size as a 12-bolt except the axleshafts, upgrade those, add a spool and the gears of your choice, a rear girdle cover, and weld the tubes to the center and you will be stronger than a junkyard typical 9-inch.
I've run a completely stone stock 8.5" with Richmond gears into the mid 11's, 1.6x 60' times for 15 years in a all-steel '72 Nova, lifting the front tires 6", 400+ 1/4 mile passes and have yet to break anything.
These are a lot tougher than people know or give credit for, it is the 8.2" 10-bolt that is a weak player.
Stay with what you have and beef that, don't waste your money doing the 9" Ford IMO.
Old 02-04-2010, 10:42 PM
SSedan64's Avatar
X2. What above posts said ^^^.
Old 02-06-2010, 03:35 AM
well sounds good. i actually did not know that it was that strong. my only question is if i leave the 28 spline will they hold up good? i am just running short on the extra cash. if i mini spool do i have to do the clip eliminators if i dont will it hold up. with my set up what would make me the best 1/4 mile time 373 or 410 gears for that 10 bolt
Old 02-06-2010, 06:07 AM
ericnova72's Avatar
More for Less Racer
I've run 28 spline for a long time in my Nova, but this is with a posi unit, spools are a lot harder on axles. I've got C-clip eliminators and would consider them manditory with a spool, just like the NHRA/IHRA track rules say - Any locked rear must have positive retention device on the axles.
Would need to know more about the torque converter and trans to pick a gear ratio, but if you are planning track time I am going to say you will be happier with the 4.10's. You can always try the 3.73's that are already in the rear with a spool or posi unit and see what they are like just to get an idea of which way you might want to go.
Your 327 will be happier with 4.56 gears if you don't have to hit the highway often, need to get it revv'ed up to get its power.
15 years ago I did a '76 nova for a girlfriend(her family was into racing too) with a 9-1 compression short rod 383, home ported 487x smogger heads, 2.02 valves, Crower 268/276 @ .050" .545"/.563" lift 108 seperation Solid cam installed 7 degrees advanced per Crowers instructions, Vic Jr and 750 Holley Vac Secondary, 1-5/8" headers, TH-350, 2800 stall, 4.11 gears. Went 12.50's with 12.10 potential, totally stock 28 spline 8.5" rear with factory Eaton posi from '75 Trans Am. Car was slow off the line(1.8xx 60" times) but had a good top end charge at 112 mph. 26" tall tire(McCreary/American Racer G-60/15 "dirt compound" IMCA tire makes a great DOT legal "cheater" tire). Car really needed 4.56 gears, or three more points compression LOL
There is a lot you can do to lighten the car in the bumper area - there are those heavy gas dampers that hold the bumper, and that heavy inner reinforcement beam inside the bumper shell on both ends of the car, almost 200 lbs in this excess stuff alone.
Old 02-06-2010, 06:28 AM
Rickracer's Avatar
Originally Posted by ericnova72
.... there are those heavy gas dampers that hold the bumper, and that heavy inner reinforcement beam inside the bumper shell on both ends of the car, almost 200 lbs in this excess stuff alone.
...and every 100lbs. is roughly equivalent to a tenth in the 1/4 mile.
Old 02-06-2010, 10:00 AM
A mini spool does not require c clip eliminators. The c clip axles will work. A mini spool is designed for dirt track racing. If I was building this rear end for drag racing I would use a regular spool and a set of 30 spline axles with c clip eliminators. If you wanted to go even bigger I have a new set of 33 spline axles with c clip eliminators that a friend ordered and decided not to use. You can get a good deal on them, but you will need a 33 spline spool to go with them. I just wouldn't feel right about the stock 28 spline axles with a mini spool.
Old 02-07-2010, 12:18 AM
ericnova72's Avatar
More for Less Racer
Agree with all of this ^^^, a mini spool is a poor choice on pavement(even though I have friends who have done it) and by design puts all of the power load on that skinny little cross pin in the case. IMO C-clip eliminators are mandatory with the mini spool even though you can install it without them, it is just safe insurance as you run a much greater risk of breaking a stock axle with the spool.
406 sbc, build questions manchildau65 Engine 53 04-03-2010 06:59 PM
I'm the new guy with a lotta questions. Can you answer all of 'em? LittlePwny Engine 17 04-10-2009 02:08 AM
Unibody Rollbar Question Thump_rrr General Rodding Tech 37 03-10-2009 10:55 AM
9 inch ford G body rear axle questions, advantages STD spring, coil over eatonde Transmission - Rearend 9 01-21-2009 11:11 AM
9 inch question 19nova72 Transmission - Rearend 7 03-12-2005 03:15 PM
