UV Bondo???!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2004, 05:23 PM
zipfactor's Avatar
Last journal entry: Just starting
UV Bondo???!!!
I was at autozone today looking to pick up some body filler and I ran across a can of bondo brand filler called UV body filler. It says that it requires no hardener to be added, it cures from uv light. It says on the label that it is stronger and more flexible than regular bondo. Has anyone ever had experience with using this? I thought about picking it up since it is pre-mixed, but, i wonder if it holds up as well. Any comments?
Old 04-09-2004, 06:10 PM
BarryK's Avatar
UV Filler
This product first came out about 10-15 years ago by the same company and it was a major flop.
Would not always dry just a mess.
I had heard they came out again about I guess a year ago for the do-it yourself market.
In last three years UV curing has come a long way so I'm sure you would not have a problem with the new product.
We now have UV cure primer with use of a special lite. and a lot of RDC money is being poured into this right now as some see this as the wave of the future for automotive paints one for VOC and two for safety.
The only concern I would have is body filler is one of those products that start losing solvents from the day its made and being in an chain automotive parts company, how old is it?
Old 04-09-2004, 10:36 PM
dharroald's Avatar
Tenacious D Rocks!!!
i've used the stuff on my truck. it's some really odd stuff. it hardens into almost like a piece of plastic but will remain flexible. the stuff is hard to sand by hand but it can be done, i recommend using a compressor. i went pretty thick with it in spots, over a 1/4 of an inch, and i can't tell it's even there. if it doesn't get sun it WON'T harden. it remains kinda sticky. if you have plenty of time to mess with it, i think it's worth atleast trying.
Old 04-10-2004, 10:39 AM
zipfactor's Avatar
the stuff is less than a year old i think
Old 04-10-2004, 03:23 PM
4 Jaw Chuck's Avatar
You can have my partially used can, it's garbage unless cured in direct sunlight and is still tacky even after a couple of days, having to do the work inside is no treat either since I usually do body work outside to keep the dust out of the garage. It is very inconvenient to have to roll the car outside to cure it. Maybe with a black light it would work better but for me it's just another wasted 15$, the old fashion stuff works way better if you ask me.
— Han Solo
Old 04-10-2004, 09:50 PM
milo's Avatar
point on positive
I was in a rush the other day and didn't have time to get what I use regular (Rage) and was forced to go to one of those auto stores. I saw that UV stuff and remember seeing primers that are coming out latley the use a special light to cure. I guess it works along the same princible but forgetabout it.
I keep looking and found a can of Brand --> Bondo* "Ultimate" in the sky blue can, and wanted to post that I thought it was better than I expected. It mixed smooth and creamy, was easy spreading and cut quick as well, It's the can with the yellow M in ultimate.
Old 04-10-2004, 11:53 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Never tried the UV only bondo stuff but if you want any polyester resin based system to really harden fast, use the prescribed hardener then set it in direct sunlight. Will harden like a rock in less than an hour. Works great for fiberglass parts that you are doing in cool weather. Left inside, those parts take a couple of days to set and still are rubbery. Set them in the direct sun for an hour and they will be completely cured.
Old 04-11-2004, 07:43 PM
dharroald's Avatar
i got the uv for $4 on sale at atwoods. i don't know the usual price, i haven't used it since last summer, the can is sitting in my toolbox and everytime i open it, it seems like the smell just lingers for 1/2 an hour and follows you around. its weird
