V-6 T-5 From S-10 to 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2013, 09:08 PM
Read through a bunch of searches,what I really need to know is,a customer dropped off a T-5 from a later model 4.3 V6 S-10,and wants me to put it in his 55 Chevy pickup with a 77' 350 Chevy with stock truck 4sd. Not concerned with linkage or throw,can handle that,do 350s have different size flywheels,is the old 4sp the same corse spline shaft,is the input saft the same lenth? I know a lot of guys do this swap,I know Fords inside and out but not Chevs...
Old 04-01-2013, 10:29 PM
RWENUTS's Avatar
All the info you'll ever need is in here.
TRANSMISSION - T5 Tech Links - THE H.A.M.B.
Old 04-01-2013, 11:16 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Early 4.3 T5's is rated only for 170lbs of torque.Those are non-W/C.
The difference between Pre 86 chevy 350 and post 86 350's haaslyd Engine 12 12-15-2011 09:37 PM
Olds 350 Diesel Converter behind Chevy 350 FastOrange Transmission - Rearend 2 03-18-2011 09:20 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 01:44 AM
Chevy 350/350 cam - poor performance Chuck V Engine 5 08-12-2004 11:23 PM
53 Chevy 350/350 starter won't turn over tm454 Electrical 6 07-15-2003 05:40 AM
