v-6 to v-8 and vice-versa mount differences: - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2012, 07:53 AM
Banned User
Can you tell me in great detail what differences, if any, are there when you are converting from a chevy v-6 to chevy v-8 OR switching from v-8 to v-6?
So that we are all talking the same thing, let's define a few things:
1) We are dealing with ONLY chevy small block engines, so both the 6 and 8 are 90 degree small block engines. We are not concerned (at least not yet) with buick v-6's or the chevy 60 degree v-6, or inline 6's.
2) For sake of discussion let's say that the ENGINE MOUNTS are the clamshell mounts that bolt to the side of the engine. FRAME MOUNTS bolt to the frame at or near the front crossmember.
Can you use the same mounts or do you have to move the frame mounts? Will it all drop in?
Old 06-25-2012, 07:40 PM
BigChevyFTW
Guest
Bolt in swap!
Old 06-25-2012, 08:26 PM
This is not just a bolt in, the v6 is 3/4 of a v8 but 2 cyiinders are remove from the middle of the block.
Poly flex underneath bodyfiller (Platinum Plus) and vice versa? JohnnyK81 Body - Exterior 7 06-02-2011 10:25 PM
Vice Grips: Which brand? stinger12 Garage - Tools 40 08-15-2010 04:43 PM
***? Buick cars with Olds engines and vice versa blown69stang Hotrodding Basics 17 03-30-2006 05:30 PM
welding vice grips? modas Body - Exterior 20 09-26-2005 09:39 AM
Why do shorter rods increase piston speed and vice versa? brian12c Engine 7 03-09-2005 09:41 AM
