V-8 vega :front coil spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2010, 07:58 PM
hello all,
i am building a v 8 vega wagon . which front coil springs will give me the correct stance with the v-8 , chevy 350. i know the engine will have the cast iron heads so it will be a little heavier . thanks for any input.
again thanks
rf55556
Old 06-28-2010, 02:11 AM
i had a 72 wagon years ago. I set it up with 4cyl a/c car springs. They were about right for iron heads and a aluminum intake. Mine was 350 hp 350 with a t350 trans.
Old 07-01-2010, 01:56 PM
djv8ga's Avatar
What year is the Vega? If it's older than a 1975, you will NEED to replace the lower control arms with 75 and later Monza or Vega units. These are deeper and use the longer springs. After that is done, use a set of V6 Monza springs. There are 3 types, but the 2 most popular are Moog #5622 (V6-No AC) and #5624 (V6-AC). Also be aware that not all L.C.A.'s have sway bar mounts. If you're not a member already, come join us at http://forums.h-body.org/
Old 07-01-2010, 03:53 PM
jon72vega's Avatar
WOW, I could have had a V8!
djv8ga described it well.
And do check out http://forums.h-body.org/
There's alot of good information & people there.
Jon
http://1972vega.wordpress.com/
gasser front spring question new_rat_rodder Suspension - Brakes - Steering 4 12-20-2009 04:39 PM
Front Coil spring orientation on IFS fosterdl Suspension - Brakes - Steering 2 05-16-2007 05:51 PM
Vega Coil Springs...Hey Deuce... yekoms Suspension - Brakes - Steering 6 12-18-2006 03:58 PM
Sizing Front coil springs JNJo39 Suspension - Brakes - Steering 4 05-09-2006 03:57 AM
69 Torino front coil instalation tips? MM in NM Suspension - Brakes - Steering 7 01-05-2006 08:13 AM
