V-band flanges for turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2004, 11:07 PM
Does anybody know a good place to get V-band clamps and weld-on flanges?
BTW, when you measure the flanges on the turbo, you measure to the outside edge of the inner lip, right? Which would give me 2 1/2" outlet, compressor side, and 2 1/2" inlet, 3" outlet, turbine side... Does that sound about right for a GTP-38?
Thanks.
Old 09-05-2004, 06:31 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
That sounds right on the sizes. You actually have to measure the top and the bottom of the lip along with the angle of the bevel to get the right clamps. If it is a GTP38, I would just go to ford and get the clamps. There are about a million different sizes of clamps and it has to be the perfect size to fit and seal properly. I had to go to a turbo rebuild shop to find a clamp for my 5 inch outlet. We went through about 20 (almost) 5 inch clamps before finding one that was dead on. As for the flanges, I dont know. I ended up making one for mine from 1/8 inch plate steel and welding it to the pipe. Most of those flanges are cast iron from the factory and there are not mild steel replacements that I know of.
Chris
Old 09-07-2004, 10:12 AM
I found these guys...
http://www.boostlogic.com/
They have weld-on flanges in stainless and mild steel. They look like they might work. If the clamps are specific, I'll probably just pick them up from Ford, like you suggested.
-Rich
