Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V Belt for 5.7 liter Vortec Block
Old 01-16-2005, 01:57 PM
Sly's 53 Suburban's Avatar
Sly's 53 Suburban Sly's 53 Suburban is offline
Last journal entry: Built a shop to expedite building my toys
I may be wrong but, I thought they started using a reverse rotation water pump in 1997 when they went to a serpentine setup. I know I can use either water pump depending on what belt system I choose. I'm running the Edelbrock manifold designed for the Vortec heads and an Edelbrock #1406 600 cfm carburetor. My original post is in reference to the brackets. My plan is to purchase a long neck regular rotation water pump. I need brackets from a donor with alternator and A/C pump mounted inside and above valve covers. I was hoping someone here had done this before and would tell me what their donor was, saving me the time scouting wrecking yards to find something to work.
