V-Belt codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2005, 11:02 AM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
V-Belt codes
I am working on my 1955 2nd series Chevy truck. I am installing power steering and am trying to get the correct belt length for the PS pump. Seems that I used to be able to tell the length of a belt by its number. But I have forgotten. Can someone enlighten me?
I have a belt # 17485 13A1230 Does the 485 mean 48 1/2" in length and the 17 means 17/32 wide. And what does the 13A1230 mean? Dang I think I'm getting old.....
Old 05-27-2005, 01:44 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Used to be able to tell by the Gates No. They changed them so now you can only get close. Run a string around the pulley's. Belt's are measured on the inside BTW.
Old 05-27-2005, 08:06 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Sounds like a DAYCO belt, right?
Your assumption on the 17485 is correct IMHO.
13A1230 is a number that is used by Gates (and others) that similarly represents it's metric measurements.
Breaking the P/N down...
13 = 13mm wide (rounded)
A = Automotive
1230 = 1230mm (rounded to nearest 5) inside circumference.
Doing the math...
25.4mm = 1 inch
so 1230 / 25.4 = 48.425 inches
and 13 / 25.4 = 0.512 inches
... which roughly corresponds with the Dayco (Imperial)measurements.
Don
(NAPA Parts Store Mgr -- Olds, AB Canada)
Old 05-27-2005, 08:20 PM
skeeveman's Avatar
I am the Antirice
Great post Don!
Old 05-27-2005, 08:58 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
metric
In Canada we use the metric system. It's really simple.
Old 05-27-2005, 10:40 PM
gator412's Avatar
Thanks Don...I knew someone had all the answers! This thread should be saved!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Fan belt problem on rebuilt 406sbc 406chevelle Engine 8 06-28-2008 10:53 PM
Squeeling Fan Belt - Out of true Pulley Billy Boy Engine 3 02-15-2005 06:51 PM
Timing Belt ap0001 Engine 2 09-20-2004 10:22 AM
belt breaking all the time oldcarguy85 Engine 14 01-14-2004 05:38 PM
