v belt pops off under high rpms - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2011, 04:31 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I have a SBC with v belt style front accessories. Whenever I take the engine to 6000rpms or higher the belt that drives the waterpunp and alternator pops off.... any ideas.. pulleys all look pretty damn close
Old 08-01-2011, 04:39 PM
NOlowrider's Avatar
US Navy-Retired
I had the same problem on my BBC. I took a lazer light and laid it in the groove and shot it to the other pulleys. It revealed that I was about 1/8" off. I shimmed it out and it fixed the problem. Also, What type of alt bracket do you have. Sometimes they will flex under heavy load and allow the belt to mis-align.
I now have a march bracket and it doesn't move at all. May have to shime the water pump pulley also.
Also, you may want to try a belt that fits totally inside the pulley.
Just a few thoughts.
LATECH's Avatar
Last journal entry: New Gas Tank
Either they are mis aligned or your getting a lot of belt deflection (whip) and it is slinging the belt as a result.
Small blocks had the smog pump below the alternator , that is where you want to run an Idler, to stop the deflection.
Old 08-01-2011, 05:05 PM
Listen and Learn
Wiki Edits: 7
I just realized I don't have the bottom bracket in the picture on... Will it make a difference
Old 08-01-2011, 05:07 PM
LATECH's Avatar
It needs to be on, the alternator is probably flopping around causing the trouble.
Old 08-01-2011, 05:09 PM
Listen and Learn
Wiki Edits: 7
okay brb ill run out and figure out where it goes.
Old 08-01-2011, 05:23 PM
NOlowrider's Avatar
US Navy-Retired
I would say that is def your problem.
I would ditch that one and get one simular to this.
http://www.summitracing.com/parts/SME-2000/
Old 08-01-2011, 06:12 PM
Listen and Learn
Wiki Edits: 7
Hmm that looks a lot nicer and isnt priced too bad. Thanks for all your input. Ill take the car out tomorrow and do some pulls and see how the belt holds up. Thank you everyone for the quick responses!
Old 08-01-2011, 06:34 PM
NOlowrider's Avatar
US Navy-Retired
No problem. Hope we helped.
Old 08-01-2011, 08:25 PM
Wiki Edits: 27
back in the day
Run a smaller crank pulley so your belt does not go as fast. we used to get corvette pullies. some guys would explode a generator with a good high rpm cam, carb, headers etc. not as much charge at low rpm
Old 08-01-2011, 09:26 PM
68NovaSS's Avatar
Wiki Edits: 9
I wouldn't change to smaller pulleys, that would slow down your water pump, etc. If alignment is good, try deep pulleys.
Explode a generator??? Can you explain? If the system isn't calling for charge, and the regulator is working correctly, why would it be an issue?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 08-02-2011, 06:56 AM
Centrifugal force. It doesn't even need to be wired. I've never seen it but I can sure believe the possibility as an alternator has a lot of mass, poorly shaped, and is over driven.
Old 08-02-2011, 07:11 AM
Wiki Edits: 27
cavitation
Hopped up Ford flatheads would cavitate the water pumps at high rpm's create enough vacuum that the water would vaporize , slow down liquid flow. a problem in boat propeller design. In the old days some guys would modify the water pump impellers . My fan belt used to turn upside down, and become round like a rope because of misalignment. generator moved to make room for all those carbs.
Old 08-02-2011, 07:52 AM
68NovaSS's Avatar
Wiki Edits: 9
Maybe if it spun your motor up to 20 or 30,000 rpm's? I've thrown and rolled belts in some of my modified flatties years ago, and on my blower motor, but an alternator "exploding"? Whatever...
Old 08-02-2011, 08:18 AM
I would have called anyone a liar telling me a ball joint in an upper control arm in a Durango blew up when cutting out the rivets - had I not been healing from shrapnel in my arm and a bruised gut as I type this. No, it didn't "pop", it blew the hell up leaving me deaf in the left ear for the rest of the day. An alternator blowing up? Not likely, but who am I to call BS?
Rpms too high prettyboyced Transmission - Rearend 25 11-26-2010 05:28 PM
High RPM pops thru new summit carb PontiacGPs4Life Engine 2 09-06-2009 04:08 PM
TH400 shifting high rpms dieselherb Transmission - Rearend 1 08-20-2006 11:56 AM
BBC hemorrhaging oil at high rpms - what's the deal? LeadfootBob Engine 8 07-03-2006 05:40 PM
Car is smoking at high rpms... redcamaro4spd Engine 4 12-23-2003 05:15 PM
