v-belt to serpentine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2010, 10:01 AM
Looking to swap from v-belts to serpentine set up in my 85 c10 350. got a whole accessory set up off of a 91 c1500 with a 350. I know so far that i need to get a water pump for a 91 but i've also heard that you need to relocate the alternator? is this true? if so where can i find a relocation bracket?
Old 11-04-2010, 12:15 PM
If you took everything from the 91, you should have two castings, one of each bolt to each head. The alternator will be located on the drivers side bracket along with the power steering pump below it. The passenger side bracket will carry the AC compressor or if not so equipped there will be an idler pulley in that location. If you have to relocate the alternator from the passenger to driver's side, the parts houses speed shops carry a wire extension kit for the relocation, this is way simpler and cheaper than trying to relocated the alternator to the passenger side. Also keep in mind that the serpentine power steering pump mounts differently than the V-belt and probably won't fit the serpentine factory bracket.
You need the water pump for the reverse rotation of the serpentine compared to the V-belt and if this uses a pump driven fan, you also need the serpentine fan.
Bogie
Old 11-04-2010, 12:20 PM
FastOrange's Avatar
your belt setup should look like this.
This setup is off a 1994 4.3L
Old 11-04-2010, 03:05 PM
so what am i lookin at havin to do to make the powersteering pump work? i was planning on using the powersteering pump off of the 91. will this not work?
Old 11-04-2010, 03:36 PM
You'll probably have to get the later model pump and reservoir from the serpentine belt donor vehicle. been a while since I done one of these swaps, but if memory serves, the older pumps won't bolt to the cast bracket.
Bogie
Old 11-04-2010, 04:29 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Too many plug wires for a 4.3 V-6 . Is it a 4.8 V-8 ?
Old 11-04-2010, 04:54 PM
FastOrange's Avatar
its a 350, belt setup is off my 4.3L, exact same as a V8 setup.
Old 11-04-2010, 04:55 PM
FastOrange's Avatar
Bogie
You will have too, the Serpentine Pump bolts to the belt bracket.
Old 11-04-2010, 04:56 PM
FastOrange's Avatar
Should work just fine, I would snatch the hose off the 1991 as well, one of them threads into the pump, the other hose just clips over a nipple and hold it down with a clamp.
Old 11-05-2010, 01:25 AM
will the water pump off of the 91 work on the older block without modification?
Old 11-05-2010, 10:42 AM
Yes, with the OEM Serpentine system. It is the same old, same old casting with a different impeller to pump coolant the "normal" way into the engine while being turned counter-clockwise which is backwards to the original V belt pump.
Bogie
Old 11-05-2010, 12:14 PM
FastOrange's Avatar
Yes, only thing that might be different is it probably doesn't have a water port drilled and tapped init, but probably has the boss.
Old 11-07-2010, 06:28 AM
6426yy's Avatar
I just did this set up this summer on my '83
http://www.youtube.com/watch?v=0yxZTYwK8uM
Switch from serpentine to V belt 454headache Hotrodding Basics 5 10-28-2009 03:21 PM
Free Serpentine Belt Wear Gauge GrumpyOldMan0_0 Garage - Tools 7 09-29-2009 06:41 PM
Serpentine belt slips 96 F250 Furytom Engine 8 11-26-2008 09:02 AM
serpentine belt water pump direction? trucks_chevrolet Engine 16 04-15-2008 10:49 AM
serpentine belt smell 67tiger Engine 11 06-16-2007 12:06 AM
