Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 01-16-2004, 07:00 PM
bowtieorbust bowtieorbust is offline
V6 to V8 mini van ?
I've got a 1989 GMC Safari mini van, with a 4.3 TBI vortec V6, a 700r4 tranny, 3.40 gear's. The tranny is in good shape but the engine has over 150,000 mile's on it, and has a knock in it witch i kinda think that it's a thrust bearing that's knock'in. Was just wonder'in how much work it would take to incorperate an older 355 sbc that's around a 1976 engine. I know that some say the 4.3 V6 is 350sbc with two less cylinder's. Also is there an intake for the 350 sbc that would accept the throtle boddy from the V6, along with a V8 dist. that'ill plug into the electrical system.
  #2
Old 01-16-2004, 07:04 PM
poncho62's Avatar
poncho62 poncho62 is online now
Last journal entry: 51 Ford F1
Wiki Edits: 5
This is a popular swap. Get an 88 or newer engine for it. It will have the throttle body all set up on it for you.
IGNORE TROLLS & THEY WILL DISAPPEAR
Ontario Rodders
Old 01-16-2004, 07:15 PM
badknuckles's Avatar
badknuckles badknuckles is offline
you talkin to me?
thats a popular swap????
just go's to show ya you learn something new everyday
Old 01-16-2004, 07:17 PM
poncho62's Avatar
Wiki Edits: 5
I know of 3 of them in our town...........Maybe they are only popular around here.
Ontario Rodders
Old 01-16-2004, 07:20 PM
you talkin to me?
ive never seen it but it sounds like a neat swap.
i dont think those vans weigh too much either.
i still like the old 70's vans you used to see around with the beefed up small blocks and sidepipes
Old 01-16-2004, 07:30 PM
poncho62's Avatar
Wiki Edits: 5
And the shag carpetting, water bed and the "Keep on Truckin'" guy on the back window?
Ontario Rodders
Old 01-16-2004, 07:31 PM
V8 S-10's Avatar
V8 S-10 V8 S-10 is offline
v8s10.org
Theres a whole forum for V8 swaps in Astros/Safaris on www.astrosafari.com
I've heard that theres more room for a V8 in a Astro than there is a S-10.
Old 01-16-2004, 07:34 PM
you talkin to me?
hey poncho dont forget the shaped window on the side like the circle or the moon and definately dont forget the little fridge
Old 01-16-2004, 07:36 PM
Just wonder'in if that Edelbrock TBI manifold #3704 for the 87-95 305 to 350 engine's will work on my (1976) 350 sbc, because on the web site it look's as if it would.
Old 01-16-2004, 07:42 PM
poncho62's Avatar
Wiki Edits: 5
Not unless you change the heads too.
Ontario Rodders
Old 01-16-2004, 07:44 PM
you talkin to me?
if you change the heads to newer fuel injected heads it would.
or as i have seen 100 times i you wanna do a little drilling on your manifold i wouldnt try it though.
Old 01-16-2004, 08:18 PM
Ok there follow gear head's, This shore seem's like a lot of work, i had no idea that there was so much to swapping in a V8 engine. I think it's time to move on to another brain storm.
Old 01-16-2004, 08:27 PM
tom_scott tom_scott is offline
Check out a company called Racecraft Conversions....they sell a kit to dothis...or you can just move your motor mounts up three inches on each side.....I plan on doing this myself on an 89 Astro
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
