V6 -V8 swap Car wont crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2011, 02:02 AM
im having a problem, i converted a v6 camaro to a LT1 V8 car but she want crank. i rebuilt the motor and dropped it in. i had a donor car and took the computure,wire harness and put it in. im not getting and fuel or fire but shes turning over fast enough but its not hitting. im thinking its the computer but don't want to buy one and thats not the case.can anybody HELP!!!!
Name:	photo[1] - Copy.JPG
ID:	56133   Click image for larger version
Name:	photo[1] - Copy (3).JPG
Old 06-17-2011, 07:22 AM
You are going to have to go back over your work and make sure that all the wiring and connections are fine, all your grounds are fine. How are the fuses and relays? Time to diagnose.
Old 06-17-2011, 11:17 AM
You say it won't crank, then you say it IS turning over. Which is it? To most people, "won't crank" means "doesn't turn over with the starter".
In any case, it sounds like a VATS system problem. The computer is looking for the correct resistor chip in the key and your old ignition key apparently isn't the right one. You need to change the VATS programming or bypass it.
Old 06-17-2011, 12:14 PM
X2
Bogie
Old 06-17-2011, 04:31 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
X3, I've installed over 100 remote starters using bypass modules from here . Just figure out what you have, VATS, CAN, etc., or, like Bogie says, get the right keys.
Semper Fi
Old 06-17-2011, 09:20 PM
so do i need to go to a chevy dealership and get the computer program to the key or go get a bypass module put on guys
Old 06-18-2011, 06:13 PM
Steel's Avatar
The Ultimate Lurker;)
Does your security light stay lit? Have you double checked your ground coming off your PCM. Without that ground it will have symptoms similar to what your having....
Old 06-18-2011, 07:36 PM
Yes Its stayn on plus I ran a jumper wire off the negative battery post and stil the same
Old 06-18-2011, 08:32 PM
Steel's Avatar
Then as everyone else has said, you need to bypass your VATS. You may be able to have the VATS tuned out of your PCM. Go to LT1PCMtuning.com and give Solomon a shout and see if he can help ya out.....
Old 07-05-2011, 09:13 PM
I look into the vat and my ignition wires were broke in the steering column I replaced them and the security light went but still having the same problem. I check the fuel injectors wit noel light and they didn't flash too now I'm lost
Old 07-05-2011, 09:22 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What do you mean you looked into the vat?? The light going out isn't an indicator the ignition is energized, you need to disable (bypass) the VATS system with a module, they're relatively cheap until you get into the CAN series.
Semper Fi
Old 07-14-2011, 08:09 AM
Not tryin to sound slow but what is the module bypassing plus did the BCM needed to be change to or that's plays no part
Old 07-14-2011, 01:15 PM
RippinRon's Avatar
VATS Vehicle Anti Theft System, there is a resistor on the key. Google it or check thirdgen.org
Old 07-24-2011, 06:22 PM
I got the VATS bypass module that will fit my car but having a hard time installing it. I download the guide to install it but its shows and remote starter to connect to also Should i get a diagram of the car`s wiring to the theft module and put them together like....im ready to give-up on the build NOW.....
Old 07-24-2011, 08:25 PM
Steel's Avatar
You will need to find a wiring diagram and identify the VATS wire coming from the PCM going to the ignition. Then you will need the return wire coming from your ignition to the PCM. Once you find them you just terminate the module wires across them completing the circuit thus taking the key resistor out of the picture. I'm sure if you Google it you'll find the diagram you need..........
350 wont crank GMCustom Engine 4 02-11-2011 10:31 AM
motor swap it wont crank at all help? 81scottsdale400 Engine 17 12-23-2010 02:54 PM
Wont crank TroyBoy Electrical 9 09-03-2010 07:14 AM
Wont crank Niko1080 Engine 3 07-22-2009 02:35 AM
Car Wont Crank ponybuster Engine 13 11-28-2003 07:12 AM
