V6 Vortec Head interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 09:11 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have a 92 Chevy 4.3 Z code, TBI that needs a valve job. Will the newer Vortec V6 heads interchange?
If so, I assume I would need a newer intake also. Were the later truck Vortec's TBI also?
Is there anything to gain by going to the newer heads if it is even possible?
Thanks,
Old 03-18-2009, 02:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
“Real” Vortec heads (kidney-bean chamber and vertical intake manifold bolt pattern) began in 1996, and used SFI. They will bolt up to your engine.
Edelbrock makes a 4 bbl. dual plane intake for them, p/n 2114.
Old 03-18-2009, 04:31 PM
BOBCRMAN@aol.com's Avatar
When you get into Vortec 4.3 heads. You get into a big bag of worms. There are at least four different head sets. All will bolt to the block. But, getting intakes/rocker arms to bolt to them is another matter. There are different bolt patterns and port configurations. Even different temp and knock sensor locations.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
vortec head coolant sensor '71 Chevelle 307malibu Engine 20 10-13-2008 08:23 PM
LT1 head to vortec head 46 chevy pickup Engine 4 08-30-2008 07:27 AM
Vortec head machining? bonzipenguins Engine 6 02-07-2007 12:04 PM
3.8L V6 head question 68chevelle_ss Engine 7 04-28-2004 06:57 AM
