Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #411 (permalink)
Old 03-20-2009, 01:42 PM
marnell79 marnell79 is offline
Sounds Good. Did you have to re-enforce the heater channels? Did you build your flour as welded to the bug or frame. I got my for 8.8 rear end installed and the tires only stick out about a 1 past the fenders. I think i will leave it i kind of like to look. Finally the engine and trans are also mounted and I am finishing up the rear by making the frame mount for the rear leafs. Then I was going to re-enforce the heater channels with 1.25 Box Steel and built my floor off of.
