V8 1973 VW Beetle Project - Page 36 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #526 (permalink)
Old 10-21-2009, 09:30 AM
life is a temporary assignment
I think it will work ... I ran that rad in my rat rod...You should be OK,, I would put the duct.... I don't think you will need a shroud...
  #527 (permalink)
Old 10-21-2009, 09:40 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Sounds good to me. Thanks for the feedback.
  #528 (permalink)
Old 10-21-2009, 09:48 AM
You can always add the shroud if needed..
Your fan already covers more then 80% of your rad..
  #529 (permalink)
Old 10-21-2009, 09:54 AM
That's what I was thinking. The fan covers a majority of the rad. There wouldn't be much of a shroud. Thanks again!
  #530 (permalink)
Old 10-21-2009, 11:18 AM
NO SHROUD IS NEEDED - THE OUTER EDGE OF YOUR FAN IS THE SHROUD. ITS IS NEAR FLUSH TO THE RADIATOR SO A SHROUD WOULD ONLY DIRECT AIR AFTER THE FAN, NOT INCREASE COOLING. IF THE FAN WERE MOUNTED AWAY FROM THE RADIATOR, LEAVING A GAP TO FILL, THEN A SHROUD WOULD BE NEEDED. HAVING A FAN IN A POSITION AWAY FROM THE RADIATOR AND THEN SHROUDING UP TO THE FULL SURROUND OF THE COOLING FINS WOULD BE OPTIMUM, BUT YOU DON'T HAVE THE ROOM FOR IT.
THE INLINE COOLING FILL NECK IS A GREAT IDEA.
JUST REMEMBER THAT THE FILLER MUST BE AT THE HIGHEST POINT IN THE COOLING SYSTEM, OR THE HIGHEST POINT MUST HAVE A BLEEDER. YOU MAY ALSO STILL HAVE TO USE A VACUUM POWERED COOLING SYSTEM FILL TOOL.
CHEERS ... KEEP UP THE GOOD WORK AND I'LL KEEP MY EYE OUT FOR MORE BITS AND PIECES
  #531 (permalink)
Old 10-21-2009, 11:59 AM
Thanks, that makes since. I'll look into seeing if there's not a scrap piece of aluminum I could use here at work to construct a shroud. If not, I'll see how it does without one. I can always add one a little later on.
Is that something any service station could do, or you could help me out with? The vacuum system fill.
Keep me posted on your project. I'll send you some v8 bug links here in a moment.
I appreciate all your help!
  #532 (permalink)
Old 10-21-2009, 01:33 PM
THE VAC-FILL IS A TOOL I'LL SHOW YOU HOW TO USE / LET YOU BORROW WHEN THE TIME COMES. WE USE IT TO GET AIR POCKETS OUT OF THE OLD LS1 MOTORS CUZ THEY ARE A MUTHER TO GET ALL THE AIR OUT OF.
THANKS FOR THE LINKS.... PRIMO
  #533 (permalink)
Old 10-21-2009, 02:34 PM
awesome post I have just spent a couple hours at work reading it instead of working! Thanks!
  #534 (permalink)
Old 10-21-2009, 09:28 PM
techinspector1's Avatar
Wiki Edits: 326
Most any RV supply store will have a selection of 12v water pumps you can use to transfer coolant to and from the rear.
About the r&p. I think you're gonna be in trouble with bump steer. You can't go puttin' any old rack in there and you can't go whittlin' on the tie rods to make it fit. Do as you please, but I've been there, done that and I think you're settin' yourself up for a letdown. Keep the stock steering in it is my best advice.
  #535 (permalink)
Old 10-21-2009, 09:43 PM
I'm really not sure how the rack will work on the street.. But I did put a rack on this S-10.. I had to change the whole front clip,, he hit the wall at over 100 mph,, Fixed it for him.. Put the rack back on.. And he has been running low 10's for this whole season now with out any trouble.. Now That is only on the track... Now sure how it would do on the street.. But it's like tech said,, you may end up with bump steer.. Not sure.. it did work good for the track..
ID:	41399   Click image for larger version
  #536 (permalink)
Old 10-22-2009, 08:51 AM
THANKS for all the help and suggestions. I'm actually reconsidering my original radiator setup plan.
New plan. I'm going to lay the radiator flat / horizontal and use the factory vents that take advantage of the low pressure system behind the car to draw air into the "engine compartment to cool the air cooled engine, but in my case it'll cool the radiator. Also, I'll build some ductwork to direct the airflow through the radiator and out of the underside of the car which, in my mind, will keep the hot air from the exhaust and engine out.
Lastly, if I find myself in need of a little more air flow to radiator I'll get some deck lid stand offs.
I'm thinking I might not need them because the later model vw deck lids have vents to increase air flow, or is it to let hot air out from the engine?
  #537 (permalink)
Old 10-22-2009, 08:53 AM
I appreciate your input Tech! If the rack doesn't work out because of the bump steer issue I'll go back to the stock steering box / linkage.
I think it would be worth the try.
  #538 (permalink)
Old 10-22-2009, 10:09 AM
Super Beetle,, Not trying to tell you how to build your car,, But I think you will get much better results if you make the air flow go the opposite way you have it...The air traveling over the top of the car, will not want to turn into the vent, But it may try to suck it out of the vent... I really believe that you can pull more air from the bottom like you planned from the beginning with a small duct facing forward.. You can still keep it flat,, just make the air come out the vent instead..... Just a thought..
  #539 (permalink)
Old 10-22-2009, 11:11 AM
Thanks for looking out. I thought it was the better way too. I did some posting on some vw sites and it was brought to my attention that the vents in the back of the car are in a low pressure area and they're there to draw in air to cool the air cooled engine. Must work well enough to actually cool and engine.
It was also brought to my attention that an opposite effect might go on doing the scoop from under the car. I put together an illustration how I'm guessing it would work. I'm not an expert at aerodynamics, but it seems to make sense. I do watch Discovery channel from time to time. Nothing is set in stone at this point which is why I'm asking for feedback to come up with the best possible solution.
On a side note, it must work well for this car that's putting out more hp than mine will.
http://www.scottstreetrods.com/patrioticVW.htm
  #540 (permalink)
Old 10-22-2009, 11:13 AM
I was thinking the same think. The air is going the wrong way in that picture!
I like the Idea of the horizontal radiator and using the factory air outlets.
I just dont think air flowing top to bottom will work since the hot air is trying to get up anyway plus the shape of the body should create a nice draft to help sucking the hot air out. Just my opinion.
Tomi
Currently Active Users Viewing This Thread: 32 (0 members and 32 guests)
1973 super beetle adamhines55 Body - Exterior 2 06-16-2013 03:45 PM
74 VW Beetle wiring project techinspector1 Electrical 1 12-08-2011 02:54 PM
Which shocks for V8 beetle project??? zbhover Suspension - Brakes - Steering 0 08-22-2010 08:21 AM
New project coming - 68 Beetle dmc12mk3 Hotrodders' Lounge 1 08-21-2009 01:35 PM
Update on our V8 Beetle Project with pictures zbhover Hotrodding Basics 1 02-01-2009 07:11 AM
