V8 1973 VW Beetle Project - Page 38 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #556 (permalink)
Old 11-17-2009, 10:53 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Thanks zbhover and speedfoos! Post some pics when you get the chance ZB.
  #557 (permalink)
Old 11-17-2009, 02:53 PM
Last journal entry: Well finally got something different for a project...
Projects looking good, congrats man on your marriage.
  #558 (permalink)
Old 12-12-2009, 03:55 PM
where did you get your cage?
  #559 (permalink)
Old 12-14-2009, 08:18 AM
Thanks!
I bought it from swracecars.com. Here's the link to the cage I bought.
http://www.swracecars.com/store/10-P...8=11-5550.aspx
Part # is 11-5550. It's $249.99. Shipping to my work was a little under $100
I hope this helps!
  #560 (permalink)
Old 12-21-2009, 09:28 AM
Hey guys, got an update. I borrowed the wifey's camera for this set of photos.
Before I begin, I just wanted to let everyone know I found out last weekend that my wife is pregnant!!! We're both very excited and now I need to really kick this project into overdrive. I want to have it finished before the baby comes, because quite frankly, my project funds will be reduced to just about nothing. I can finish it in 8 months. No problem. I did joke with my wife, after making sure she knew I was happy and all about the baby, and I said, "OK, who's baby is it?" Comments like that is why she married me.
OK, I've finished welding up the firewall, floor, rear firewall, the floor support under the tail of the tranny and the steering mount. Also, I welded up and ground down the welds to one side of the roof / b-pillar. I also patched all the holes that were behind the dash in which the A/C / fresh air came through. There were about 5 good sized holes I had to patch.
It might not look like much but it was a ton of work.
The dash bar is kinda in the way, but you can see some of the patches. I plan to grind them smooth and I'll use some bondo to give it a clean appearance. I don't plan to put the dash back in. I'll mount my gauges to the dash bar for that racey look.
Here's part of the floor support that I had to cut out so the tail of the tranny would have room. A lot of this project I've kinda guestimated how things will fit and have prayed it works out once I go to put the part in. So far I've done a decent job at guessing. Here I had to make a small adjustment. I basically cut it out and exstentded it down. Obviously...
I also got a good used balanced drive shaft. I'm going to see if our engineer / machinist can put it on his lath and help me shorten it in exchange for some graphics. He likes fooling with remote controled airplanes so he always needs some sort of decals made up.
I got a some extra spending money, after paying all those lovely property and homeowner association taxes, and bought a few things. I bought some starter bolts so I can finally put in my starter, a new fuel pump because I got the wrong one (I need one that doesn't have the fuel return line just to simply things), and last but not least I bought a new 750 cfm carb to replace the rebuilt 600 cfm edelbrock carb. The 600 cfm I originally got when I thought I was going to run the 283. Well, with an extra 100 ci I needed more carb. I did opt to buy a Summit Racing brand carb because I've read some good reviews about it and I like how it has black accented parts instead of chrome / gold.
Also, I have the funding to take the car to get the exhaust and radiator plumbing done. So hopefully I have time to do it this coming up weekend. That means I'll be able to finally start her up really soon. I still need to run the fuel and brake lines but that's not too big a task or expense.
Last but not least, Santa is bringing me some goodies.
A gas pedal, cable, carb brackets, wilwood brake pedal and master cylinder, a shifter and a racing harness...
After the holidays I'll be in a pretty good spot. The car will be pretty close to driveable. Here's a brake down of what will be left to be done with the 8 months time.
Things to get:
a sheet of 16 gauge metal $35
Seats $320
Another racing harness $60
tach $125
3 gauges (temp, volt, oil) $25
u-joint for steering $50
u-joint for drive shaft $15
seals for windows and doors $150
wiring harness $150
head lights $15
in light turn signal kit $15
new tail light lens $65
once piece window kit $125
new (to me) front glass $40-$50
brake line $15
fuel line $5
radiator hoses $15
gas tank hose to filler neck $5
tires $700
alignment $75
carpet $50
paint for the car body and wheels $400
Total to finish = $2435
Things to do:
run gas line
run brake lines
finish trans and drive shaft tunnel
finish radiator duct work
finish engine bay
finish back / gas tank firewall / flooring
make and weld in seatbelt tabs
mount seats
body work
paint
wire up the car
lay carpet
inspect / register
DRIVE!!!....
There's still a lot to do but I'm pretty sure I can get it all done in time. If you guys have any advice on inexpensive paint for the car body or find any deals feel free to let me know what you find. With the baby on the way I'm going to have to watching my spending. So I can't exactly get PPG or HOK paint. The pricing above is all for new stuff, but some of these parts used wont hurt either.
More soon...hopefully after the weekend...
  #561 (permalink)
Old 12-22-2009, 02:40 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Congratulations.
  #562 (permalink)
Old 12-22-2009, 06:55 PM
Im trying to have an idea!
good to have parts and good to hear about the kid coming.
  #563 (permalink)
Old 12-22-2009, 08:05 PM
406 bug's Avatar
9.82 @ 139mph
You may find these interesting/helpful.
  #564 (permalink)
Old 12-23-2009, 08:59 AM
Thanks guys!
406 Bug, I'm not seeing anything. Was it a link, or pictures?
  #565 (permalink)
Old 12-23-2009, 11:07 AM
406 bug's Avatar
9.82 @ 139mph
Thanks guys!
Sorry, I tried to post pictures of my bug project . a bunch of chassis pics showing details of suspension , cage etc. Its all cromemoly round tube construction, full cage, Srtange strut front susp., narrowed 9" rear, 550hp 406 up front with t-400 full manual with reverse pattern shift.
I will try to get these pics posted (my computer skills are lacking).
  #566 (permalink)
Old 12-23-2009, 12:00 PM
Wow, sounds like an awesome ride! Try using the "Manage Attachments" button below the message box. In the box named "Additional Options".
You might want to check out v8bugs.com, cool v8 bug site and builds there.
  #567 (permalink)
Old 12-28-2009, 09:07 AM
Well, it was a great Christmas and I hope everyone's was a great one too! I got my parts from Santa, haha, and I spent all day Saturday going back and forth to get the exhaust work and plumbing done on the car.
These guys did a really good job. The son of the owner did the work. He's been doing custom exhaust work since he was 8 or so, seriously. I think he's around 19 now. They charged me $300 for everything. I provided the FlowMasters. Here are some pictures of the exhaust and plumbing.
He brought the plumbing right up to the pump. You can also see the replacement fuel pump (I changed out the one with the fuel return to simply things).
As you can see there is some pretty tight clearances. This guy worked wonders getting the plumbing around the engine and even around the oil filter. The only thing I'm bummed about is there's not enough room to add my stall dust cover. I completely forgot about that. Oh well.
Plumbing all the way back to the radiator.
Here's the start of the other side of the plumbing.
The exhaust was hung how a typical V8 S10 dual exhaust would be done, but instead of having him run the exhaust all the way back out the rear I had him dump it for simplicity sake.
And here's where the other side of the plumbing ends. Right up to the radiator.
Here's a pic with the new 750 carb installed. Looks great.
More to come soon. Hopefully a video of it running!!!
  #568 (permalink)
Old 01-04-2010, 07:54 AM
I got some more work done this weekend.
I spent I good amount of time searching for the right radiator hoses to button up the plumbing on the car. I also got all the PCV, vacuum and rubber fuel line ready to go. I still need to run a gas line from the tank to the pump though. I also installed the steering box, the steering column (to see how things line up once again), and I mocked up my master cylinder, brake pedal and gas pedal (forgot to take pictures of that. I'll get some up soon). Last but not least, I got the starter installed.
Here are some pics with the hoses tightened and ready for the first start up which is yet to come.
Here you can see I need to get a different water neck because it makes it want to stick up. I found a 360 water neck from Summit I'm going to order. That way I can angle the hose further away from the engine and so it'll tuck under the hook nicely. I'll have to think of a way to secure it which wont be much of a problem.
Here's the 360 neck.
I installed the steering box and drilled a hole so the steering shaft came go through the firewall. The steering wheel mounts in the stock location.
Here you can see where the master cylinder will be. I was mocking up the pedal placement and found that because the foot space is so tight I'll have to gas with the right foot and brake with the left foot. That's how you power brake it anyways. I also plan to just completely cut out the wiper engine compartment. It's really not needed.
More soon.
  #569 (permalink)
Old 01-16-2010, 06:46 AM
Cool Ride!
Very cool ride. I have a 1970 Bug with a mid-engine V8. I just purchased it late in 2009 so i have not had a lot of time to tweak it yet. This is actually a kit that was manufactured and I am trying to get more information on it. It utilizes a Corvair trans-axle set up. It currently is a 4 speed and it will rock and roll.
Here are a couple of pics....
Name:	SM 70v8 Frt.jpg
ID:	43250   Click image for larger version
Name:	SM 70v8 Rear.jpg
  #570 (permalink)
Old 01-16-2010, 07:09 AM
I remember that car from the Dave & Ed's Swap Meet in Canfield. It was in the car corral. I wondered what they used for a trans. Cool car!
1973 super beetle adamhines55 Body - Exterior 2 06-16-2013 03:45 PM
74 VW Beetle wiring project techinspector1 Electrical 1 12-08-2011 02:54 PM
Which shocks for V8 beetle project??? zbhover Suspension - Brakes - Steering 0 08-22-2010 08:21 AM
New project coming - 68 Beetle dmc12mk3 Hotrodders' Lounge 1 08-21-2009 01:35 PM
Update on our V8 Beetle Project with pictures zbhover Hotrodding Basics 1 02-01-2009 07:11 AM
