Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #286 (permalink)
Old 10-20-2008, 01:51 PM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Originally Posted by 31chevy
You should be using a cheeze grader or body file. it will work fast to remove body. Looks like you not applying the body with the better method. should have done an additional sweap along the arc of the fender to smooth it better. Lots of people tend to slap the bondo all on in one shot but there just going to end up sand it back off where as they could have created less work by apllying it the right way
You're right. I don't have one at the moment, but will be getting one. I did shave it down some with the putty knife.
I did spread it both ways, but just ended going the direction you see. That works well until I got to the top of the arc. Most of the bondo will stay. I started block sanding until it feathered out. It needs a little more in the center.
This is my first time really doing anything like this. So feel free to help me out.
