Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #319 (permalink)
Old 01-05-2009, 11:28 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Some updates.
A little more body work basically. I finished off the fresh air vents. They had little pin holes and needed some more block sanding. So that's done. Then I needed to close off the gap between the passenger fender.
You can tell from these pictures, but I figured it was time for some sweeping. So I had to jack up the bug and remove the front tires cause they went low. Took and filled them with some air. I took I picture so you could see just how well the stock S10 width works and perfectly under the stock fenders. The spacers are to give enough room for the vette wheels.
