Originally Posted by hutton01132005
i have a 4.3l v-6 powered super in the works full air ride all 93 s-10 blazer chasis your is a little farther than mine right now i am still working out how to fit a steering column and a brke booster in the same spot would you post some pics when you get the motor in so i can see the steering shaft/column clearance between the block
I sure will. I'll post up some pictures once i get the engine in. It'll probably be a couple more months before I get the V8 in. I'm in the process of rebuilding the chassis, then have to rebuild the trans, putting the motor together, and put it all in.
You might want to go to v8bugs.com and you can see how much space some of the other guys had. I'll still post pictures though, it just wont be too soon.
