Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #338 (permalink)
Old 02-02-2009, 04:25 PM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Finally, some updates...
A few buddies came over this weekend and we took the body back off the frame. This time she's sitting on 4 blocks at each corner instead of two, LOL! ;D
At this point I'm welding up tack welds, would've completely welded some parts but they were too close to the headline, I added a couple fish plates to reinforce the shackles I welded in, and I'm welding up the top of the body mounts.
Next, I'll weld some caps onto the front of the frame, and weld in the "bolt-in" 6 point roll bar plates I bought. I'm doing this so I can remove the body (plates welded to frame, the cage will be inside the flooring once built and I'll be able to bolt it all up) later down the road if needed. Should make for installing the engine easier.
Then the frame is coming apart, I'll weld up the bottom of the frame (suck at overhead welding with the stick welder), small parts will be sandblasted, the frame will be power washed, and then I'll paint it and start rebuilding it with new bushings / ball joints.
Once all that's done I can do the fun part. Motor, tranny and install!
