Got some work done today...
My 6 pt. roll bar bolt in conversion kit came in this past week. I mocked them up on the frame, took them to work, and then had them drilled for the bolts.
I then cleaned up the metal where the plates would be welded with a 40 grit disk.
Then welded in the plates.
Then I capped the front frame ends with some left over 1/8 metal I had laying around. I still need to go back and grind the welds smooth so it'll look nice once painted.
Next, after I grind the cap welds, I'm going to take the frame apart, sand blast the small parts at work, power wash the frame, adjust the rear ends location some so the shacks wont hit my fenders, and then it gets new paint (MasterSeries), and reassembled with the new bushings, balls joints, lowering spindles and blocks.
Then I can work on getting the engine together and rebuilding the tranny. Still lots to do til I get to that point. That's all until next weekend.
