Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #342 (permalink)
Old 02-12-2009, 09:47 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Yesterday I ordered the rest of the parts I need from Summit to put my 355 sbc together with the money I got back from my tax turn.
Fuel pump, high volume water pump, oil pump, gaskets, thermostat, comp cam timing chain, flex plate, aluminum crank pulley, harmonic balancer, etc.
Basically everything to finish off the engine. The only thing that will be used is the oil pump drive shaft, the fuel pump push rod, the block and internals (pistons, crank, rods). I'm going to freshen up the bottom end with some new bearings and piston rings. So a good clean up and a light hone is in line, soon.
Yesterday I also got a good deal on some used wheels for the V8 bug. They're C5 corvette wheels, 17"x 9.5" up front and 18"x 10.5" in the back. . The 88' vette wheels just didn't have the look I want for my car, but they're fine for mocking stuff up for now until I can buy new tires. Got them for $150 and they're in really great condition. Just the normal small scratches on the edge of rim lip
Also, on Tuesday I finished off the passenger side body mount that bolts to the heater channel. All it was needing was a piece of angle iron to reinforce it. Cut a 3" piece of angle iron, cleaned it with the 40 grit disk as well as the chassis, and welded it in. Strong and ready to go...
I can't wait to get the chassis finished so I can put the engine together!
