Originally Posted by marnell79
Im building a 1972 V8 Bug on a 1994 S10 Frame also. What springs did you use for the shortened rear leaf springs? Thanks
Cool! I used leaf springs out of a mid 90's Isuzu Amigo and I flipped them around so the longest end is upfront, if that makes sense. Here's a comparison of the two.
The longest end just so happened to be the same length from eyelet to center / mount (sorry, forgot the exact term). You might want to look around the junk yard and see what you can find, that's pretty much what I did. I believe the S10 leafs are 2.5" wide and the Isuzu's are 2" wide. I don't recall the length of the S10 springs, but if I had to guess they were 55"-60" long, and the Isuzu springs are 44" long. As long as can you find some similar in size you should be good.
