Update...
Over the past couple of weeks I've been taking care of the underside welding and have finally finished. Not much to really photograph change wise. Hopefully this weekend I'll get the chance to pull the frame out from under the car, clean up the floor, and begin painting.
I also received some more parts and tools that I ordered. Cam bearings, rod bearings, main bearings, rear main seal, piston rings, valve spring compressor tool, blocks plugs, a set of cleaning brushes, etc.
Also, I was able to find the factory stamped suffix codes on the front passenger pad of the block. Anyone know what these numbers mean?
12S231437
F 0313OKB
Last but not least I got the piston parts numbers off the top of the pistons.
TRW L3022F
.030 (which I already knew)
I was able to find out the specs on these pistons:
L=Forged in the part number
Compression height is 1.535.
Pin height is 0.927
Ring sizes are 5/64 5/64 3/16
All I've got for now. More to come hopefully soon.
