Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project - Help Needed!
  #542 (permalink)
Old 10-22-2009, 01:29 PM
wheelin wheelin is offline
air flow
you are correct on the airflow top to bottom if you duct from the bottom up it will not work i tried it on a 4x4 beetle and it was way higher off the ground the problem is that it will not let air out worked ok at low speed and off road but on the highway ran very warm drove me nuts then out of dispare we turned the fan around and removed the air duct problem solved
