Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #545 (permalink)
Old 10-26-2009, 09:35 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Thanks for all the help guys!
I got some progress done this weekend. Not as much as I would've liked. I had my 10 year high school reunion on Friday night and I had a gig the following night. I was nursing a hangover most of the weekend. Ugh...good fun though.
Any who, here were are. Got the subframe for the radiator made.
Here you can see how the rad bolts in. Fairly simple.
I then welded it into the body. Notice the penetration on the rear clip.
I then made a template for the ductwork? Basically it'll keep the hot air from recirculating with the cold air. Next I just need to make a duct to direct the air out the back of the car and which will also help to keep hot engine air from reaching the rad.
Setting up the radiator leaned back rather than flat filled the area better and will be less sheet metal work that I have to do.
