Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #581 (permalink)
Old 02-15-2010, 01:37 PM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Originally Posted by Jake_Dragon
Are you sure your getting water flow to the radiator? I have a SBC installed in the back and the radiator is up front. Its using the stock Fiero radiator and coolant pipes.
I can hold it at 190 in some pretty high temps outside and thats with the stock Fiero radiator. I have a larger aluminum radiator that I will be installing at some point but right now the one I have is getting the job done.
IF you are getting water flow then its air flow that you need to work out. Perhaps you need some big air scoops on the side to flow some air into the radiator.
I'm not getting water flow to the radiator at all. I'll fire it up again soon and see if I have fixed the issue. I'm thinking it's cause air lock. I've got some good advice from others, as well as you, that have a similar setup. So I'm still working with fixing the problems I'm having. I'll keep you guys posted.
