Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project - Help Needed!
  #608 (permalink)
Old 03-29-2010, 10:07 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
Got a few more things done off the list.
Made and tacked in some plates to cover the hole where the driveshaft runs through the firewall. I had to do it this way cause the driveshaft and column are all one welded up piece. A little seam sealer and paint and it should look decent. You can also see I filled in the holes where the gas pedal was. I'm moving it over away from the brake pedal to give me more room. It'll be closer to the trans hump, but at least it wont be an inch away from the brake pedal.
Finished off the flooring on the passenger side. This is where the trans hump comes up into the floor giving the exhaust room to tuck within the chassis.
Last, but not least, I finished the tin work for the radiator / shroud. Just needs seem sealer. I'll still make a shroud for the fan itself, but that'll come in the finishing stages.
All's left to do is make the back floor that goes above the tank, weld in some front clip supports out of some metal rod, trim some more out of the engine bay to clean the look up, and make a battery box. Then it'll be ready for the body work stages.
High five!
