Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - V8 1973 VW Beetle Project
  #613 (permalink)
Old 04-16-2010, 08:47 AM
V8 Super Beetle's Avatar
V8 Super Beetle V8 Super Beetle is offline
VW makes it, Chevy shakes it..
I did a little mocking up last night which has me still trying to figure out my alternator situation and I change my mind on my wheel direction.
The great news is the engine pulleys and radiator hose clear the hood by a few inches actually. I was worried they wouldn't. There's more room under the hood than it really looks. I did take the carb off and the breather (wait for it), but the hood closes great. I haven't seen my car with the hood on in quite some time. Here's how the hood closes minus carb, breather, and alternator. Wait for it...
The other problem, as some of you may know, is I have never put the 17" vette wheels on upfront. I've always have had the 16" upfront so I figured they'd fit, no problem, right? WRONG. The tie rod rides on the wheel. I would need 2.5 spacers to clear. I have 2" spacers on there now.
This is a repost for some, but I'm going with Weld wheels and this is how the car will look.
It'll be safer cause I'll be getting ride of the spacers AND I'm lovin' the old school drag car look.
I played with the alternator a little. I installed it as it would normally be. I was surprised it closed as much as it did. The hood is about 2" away from being completely shut.
I then disconnected the alternator and turned it as far outboard as I could. That gave me another 1/2" - 3/4" closer on the hood. It's so close to being closed. Ughh...
If only I could get the alternator to sit another 1 1/2" lower I would have it made. I'm looking into other alternator brackets.
Last but not least, my carb scoop came in, tubes of seam sealer and all my paints for the car (MasterSeries, epoxy primer, high build primer, hugger orange, black, clear coat, HVLP gun, etc). Here's a mock up pic of the car scoop. Should look ******in'!
This weekend I'm going to try and get the rear sheet metal finished and get the hood cut for the carb scoop. That should just about get me ready for the body work stages.
